LowLevelBadParameterError
Mon Oct 16, 2023 1:12 pm
I'm getting this in my log:
   Error                           LowLevelBadParameterError -- device value type for state key sensorValue must be real
Searching here for "LowLevelBadParameterError" shows it happening in a bunch of different plugins. Notably for me, the error doesn't tell me anything about what device/trigger/plugin/whatever is causing the error.
Any guidance on how to troubleshoot this? I've yet to notice it happening consistently so can't really narrow it down based on what was happening just before it posted the error. My hunch is that the entire thing errors out before it can post anything besides an error.
Tue Oct 17, 2023 4:11 am
Re: LowLevelBadParameterError
Enable sql debug logging
That will show more info ( if you have enabled sql db)
That’s how I find bad state type definitions in my plugins
Tue Oct 17, 2023 1:40 pm
I'm not much for parsing SQL, but here's the first thing I found:
560000Z-Wavereceived "Bedside luminance" sensor update to 0%|ÇÙß!A      Å72023-10-16 13:27:30.725000ErrorLowLevelBadParameterError -- device value type for state key sensorValue must be realÅÇÙß A1ÅI2023-10-16
All examples of LowLevelBadParemeterError seem to be related to those damned HSM200 motion sensors. Three different ones in fact.
Hmmmm. This one isn't an HSM200:
Z-Wavereceived "Garden Luminance" sensor update to 10 lux|ÇÛ¿A      Å72023-10-15 06:28:52.125000ErrorLowLevelBadParameterError -- device value type for state key sensorValue must be real
Tue Oct 17, 2023 1:53 pm
That looks like some characters written to the sensor value.
The author of the plugin needs to fix that.
Wed Oct 18, 2023 7:59 am
No plugin.
That’s a standard z-wave device.
Wed Oct 18, 2023 8:46 am
It appears that device is returning junk for the sensor value. If it's battery powered, you might want to remove the battery and wait a few minutes. If it's plugged in, unplug it for a few minutes.
Wed Oct 18, 2023 10:54 am
I think some plugin is trying to update the device state raw sensor value (which should always be a number) with a UI string (which contains "%" or "lux"). I'm pretty confident it isn't the Z-Wave plugin doing this (or no sensor modules would work), so I think it is some other plugin you have that is trying to update a virtual device state or something (based on that Z-Wave module)? Maybe you just have it mis-configured?
Fri Oct 20, 2023 3:24 pm
Not sure how I could have it misconfigured. Define and Sync manages with no errors.
This is from one of those extremely problematic HSM200s, which I wouldn't trust to tell me anything.
How can I further investigate? Check all dependencies? I don't have any weird plugin stuff connected to this as far as I can recall.
