Help with Autelis Jandy plugin
Wed Jan 29, 2020 6:45 pm
roquej offline
The plugin seems to be abandoned per viewtopic.php?f=144&t=8864&start=150
As the plugin needs a much needed update to support new hardware version and to address communication issues, I am willing to provide the Autelis hardware if anyone would be willing to take this over.
Anyone?
JP
Wed Jan 29, 2020 9:12 pm
Korey offline
Re: Help with Autelis Jandy plugin
Anyone?
JP
What issues are you having?
The plugin is running fine for me with my RS8 version T system, I have modified it a bit thou.. as per this post.
Other than the variable pump data not being reported back, but I use GhostXML plugin for that.
Korey
Thu Jan 30, 2020 9:38 pm
roquej offline
Korey,
Thank you for following up. I am using the version you changed. and also the XML trick to obtain the pump speed.
My challenge is that I am getting sporadic plugin errors and craches.
Using Intelliflow VS
JP
Fri Jan 31, 2020 1:40 pm
Korey offline
roquej wrote:
Korey,
JP
Weird, I have never had it crash in all the years of using it?
Have you reached out to Nick the plugin author?
He is still active on the forums especially in his Sonos plugin forum.
Korey
Mon Feb 03, 2020 12:47 pm
roquej offline
Sorry for the late response. I was traveling over the weekend.
I posted a message last year on the plugin forum, but didn’t get a response. Will try as you suggested and contact him directly.
Thank you!
JP
Mon Nov 21, 2022 5:26 am
hamw offline
Any success in getting in touch with Nick? Sure hope this plugin can be upgraded.
Mon Nov 21, 2022 1:10 pm
roquej offline
No response. I dropped using this plugin and when a different route.
JP
Mon Nov 21, 2022 1:23 pm
hamw offline
What did you do?
Mon Nov 21, 2022 1:33 pm
roquej offline
Installed Jandy iAqualink and then used the Home Assistant iAqualink integration with Node-Red to drive virtual devices via MQTT. It works well, but I am hoping for an iAqualink plugin.
JP
Sat Dec 03, 2022 10:28 pm
hamw offline
Well, we had an electrical storm in Atlanta and it killed my Autelis box. So now no hook up to the pool at all.
Could you post your solution in a little more detail? Perhaps some scripts and instructions on how to get there?
Thanks very much!
If you want, feel free to PM, or send me an email at hamw at Comcast . Net
Fri Apr 28, 2023 9:02 am
pgershon offline
Worth looking at this too I believe...
https://github.com/sfeakes/AqualinkD
Sat Apr 29, 2023 4:25 pm
Just so folks know, I'm taking a look at updating the Jandy plugin to work with Python 3. No guarantees, but so far it doesn't seem to be too bad.
Give me a few TCs to rummage through the code.
Sat Apr 29, 2023 7:21 pm
hamw offline
Thanks… unfortunately my Autelis device died hard, so I am out of luck on that one.
On the bandwagon for the iAqualink plugin!
Fri Dec 22, 2023 9:28 am
tornado offline
Hi Dave - did you get anywhere updating this plugin?
Fri Dec 22, 2023 10:59 am
I have no memory of that, but apparently so. :)
Have a look at this release and see if it'll work for you. It's not been widely tested, so I'd suggest baby-sitting it until you're sure it works properly.
https://github.com/IndigoDomotics/AutelisJandy/releases/tag/2023.1.0
