Unable to log in from another Mac
Fri Oct 21, 2022 10:46 am
Doctor Q offline
I gotta get this fixed. Ever since I upgraded to a M1 Mac Mini, I’ve been unable to log in with the client on anything other than the Mac the server is running on, I’m talking locally. The OK button is greyed out when I paste the password. When I type it in by hand, the OK button lights up but the password is rejected.
Now, I have two passwords in my keychain for Indigodomo; one for the forum and one for the web site. I’ve tried both passwords and neither one works. Does Indigo have a single sign-on and I have too many keys on my chain (not uncommon with Keychain)? I need to know this before I attempt to change the password and see if it gets fixed.
Fri Oct 21, 2022 11:56 am
Re: Unable to log in from another Mac
Neither of the above. It's looking for the username and password specified in the Start Server dialog on the Indigo server machine.
Screen Shot 2022-10-21 at 1.54.58 PM.png (244.56 KiB) Viewed 1344 times
Fri Oct 21, 2022 1:00 pm
Doctor Q offline
No go. I’m using the password that matches the user name in the Start Server dialogue. How can I change the password if I can’t find the correct one? I’ve tried all four combinations of user names and passwords. I think I need to reset somehow.
Fri Oct 21, 2022 1:03 pm
You can log into the server system, stop the Indigo server, then change the username and password in the start dialog.
Fri Oct 21, 2022 1:08 pm
Doctor Q offline
I can’t see the password in the start server dialogue, it’s blanked out and can’t tell if it’s one of the ones I have in the Keychain. Otherwise I’ll be locked out.
Fri Oct 21, 2022 1:11 pm
If you're looking at that on the server system, you can just change it to whatever you want. The server does not require you to enter a "correct" password to run.
Fri Oct 21, 2022 1:28 pm
Doctor Q offline
Ah, gotcha. I wanted to make sure on that. Thanks Fly D.
Incidentally, your MiniUnfi plugin is in use here for occupancy sensing. Works great.
